Roger63
Apparently there are no reasonably priced p/w relays available for a 71 charger. Does anyone know how and which modern relay to wire in?
I have an upgraded plug-n-play relay here, Bosch style. This is a 40a relay, plugs into car harness, and attach one ground wire. See pic below
$30 with free mailing
the relay above is for the 3 pin OE relay that uses the case for ground..I can make the same set-up for the 4 pin style that has separate ground spade on it
I don't need one, My original relay works fine. I was just commenting that the Relay harness is nice, and it's a good price because you usually have the but the connector shells and terminals in bulk, and it comes with the relay. What grade of wire are you using?
I do buy all of the components in bulk, relay, main relay harness, the plastic 3-wire connector, and the terminals are all separate. I build & market the 3 relay set for the rotating headlight motors in the 66 & 67 Chargers that are located behind the glove box....I have been selling these since 2008.
I want to start selling this one above that I posted for power window Mopars from the late 60's to early 70's
The wire that comes with the relay harness is 14ga & 16ga.
