Mike Szadaj
- 2:29 PM
- Jan 17, 2019
- St. Clair Shores, Mi
1968 Coronet. I am putting power windows in a car that didn't originally have them, using an OEM wiring harness. Where did the factory hook up the power supply wiring for power windows? The FSM has a diagram for the window wiring, but ends showing the supply marked as W1-12T, and then a note indicating "To Instrument Panel Wiring". I don't see any W1-12T on the instrument panel wiring diagram. I know 12T designates 12 gauge wire with tan colored insulation, but I don't see any W1 on the IP diagram. The FSM shows two fuses in the window harness circuitry, while mine uses one circuit breaker. This would make no difference. Because of this breaker the supply does not need to be fused. The ignition key had to be turned on for the windows to work, so the supply was controlled by the key.
