coololdcars
Is there any way to prime a big block 426 wedge motor before firing??? Dave!!!
I'm a welder by trade.Any one know what allen wrench size it is? I'll make one if I can. Also, this engine was aquired in a swap. How do I tell if the intermediate shaft and gear are correct to begin with??? Looks like it has a new cam, its covered in assembly lube.
not sure of the size of the allen,not near mine right now.not that big of a deal with the alignment of intermediat shaft,just means you will have to set up the distributer like you are doing it with a new one.tdc,align rotor to #1 and adjust to get started.then set timming with light.I'm a welder by trade.Any one know what allen wrench size it is? I'll make one if I can. Also, this engine was aquired in a swap. How do I tell if the intermediate shaft and gear are correct to begin with??? Looks like it has a new cam, its covered in assembly lube.
Cool beans....My intake is off right now so its easier to see the drive gear. If I'm reading the above right, I don't need to worry so much how the gear goes back in as log as I need to basic time the distributor anyway!??!
if you have a 1/2 inch drill i would use it. the smaller ones heat up pretty quick and forget anyone with a battery power.
i used my dewalt on the rebuilt hemi and it worked but not very long or fast. then again its like the owner, old and gets tired easily. good one:icon_thumleft:Boy you must have a girly battery drill. :icon_albino:
I've been using my Dewalts 14.4v drills for years to prime BB's with 15w40. Can run it for several minutes at full pressure.
Something we have in common there.then again its like the owner, old and gets tired easily. good one:icon_thumleft:
