I say carry a spare ballast resistor (new), spare voltage regulator (new) & a spare ignition box (used) in the trunk & leave the car alone. You might want to start running high mileage oil. Definitely do the basic tune-up stuff (plugs, wires, cap, rotor, air filter) regularly.
If you really, really like the car then maybe start slowly putting together a replacement engine? Personally, I like to have a 2nd engine built & ready to go if possible. Since it's running now, you could take you time over the next year or two.
Also, by now you're probably due for a valve job anyway. Why not find another set of heads & rebuild them now. When you go to swap the heads, you can take a peak at the pistons/cylinder walls to see how they look. You can also get a "feel" for how good your bearings are if you install a mechanical oil pressure gage.
