SOLD Probe forged flat tops NIB F/S
MikeStahl
6:23 AM
BayLands born..stuck in lynnwood WA
Selling a set of probe forge flat top pistons .040 over with the .990 pin
PN 14790-040 stock stroke 440
$425.00 plus the ride
thx for the add
Hi what Compression ratio are they and dos the Rings come with them i might be a dumb question if so sorry about that lol . And what is the .990 pin can i Use a stock Rod or do I have to buy a aftermarket set of rods for that pin size Sorry for all the questions I converted over and is my First mopar build
Mad
one of 2 ways on the .990 pin, you can bush your factory rods or use aftermarket rods.
to get a close estimate on comp at least need to know what heads you have and can give you what it would be based on stock cyl head speces
Mike
im having my 440 bored .40 over..would these work in that block? its a 74 440...motors pretty well stock other than being bored...it has 452 heads, i just rebuilt them
engine had a frozen piston, and when my cousin tried to free it up he cracked piston...so i have to bore it and get new pistons..everything else is good still
Mad with your 906's at stock ( 79 ) CC's by the book you'll be at 10.6 actual deck height and your heads cc's can very but somewhere in there you'll be
Mike
