d9103365
I have a 75 Fury (318) which has the fuel vapor recovery system. The gas cap is non-vented, and fuel vapors are sent from the gas tank to a charcoal canister in the engine bay. Most of you know what I'm talking about. Anyway, my system is stopped up and I'm wondering if its worth fixing it back stock or if I should just get a vented gas cap and solve the problem that way.
What's happening is that somehow the system is clogged somewhere, and I'm getting tremendous pressure buildup in the gas tank. When I open the tank, there is huge pressure release. The other day I filled my tank higher than I usually do (cause gas is cheap now!!) and I forgot to "burp" the tank like I usually do. After sitting for about a day or two, gas started leaking out around the fuel pump. Once I "burped" the tank, the gas leak stopped. I should also mention that my fuel sending unit doesn't work...and I have to guess how much gas to put in the tank. In any case, here are my questions:
1. What are the common causes for this problem and how difficult are they to fix?
2. Would I be better off just getting a vented gas cap and not bother fixing the elaborate fuel vapor recovery system?
At this point, I'm worried there may be some damage....I haven't bothered running it since I burped it. My guess is that the car may need a complete fuel system overhaul including new fuel pump, lines, filter, sending unit, and maybe even a new tank. I dunno, but it could get expensive. Any advice?
