WTB Pulley set
muscle72
3:52 PM
usa
Feedback: 3 / 0 / 0
Looking for a matching non ac pulley set for a 68 383.need a non ac 1 groove water pump pulley and two groove crank pulley.
got the water pump pulley-----------bob
2 groove and from the 60s?
Yes..cr8crshr/Bill :thumbsup::thumbsup::thumbsup::usflag::usflag::usflag:
Would anyone know my water pump pulley lines up great with the power steering pump pulley not the alternator pulley. Fan/alt belt fit perfectly around the power pump pulley.which is the right side.wrong side it should fit on.fan/alt belt is big around fan/alt side which it should go that side but it doesnt.not the powersteering side. It's reverse on my 383 do have the wrong water pump pulley or crank pulley?
Not sure I'll have to measure. I know the crank pulley came off a 1971 383
Crank should be right. But maybe not. Does the alternator line up with the inside groove? Kim
Yah l think it does of crank pulley or water pump pulley?
Some crank pulleys had 6 equally spaced holes, while some had 1 of the 6 offset, so the pulley could only go on one way. Not sure which years got which. I have a set of pulleys, if you are still looking.
Im still looking
Here's the crank pulley i have
Here are pulleys I have. Big blocks were red in Canada through 1966. Water pump pulley came off 1966 383 that I parted out. $40.00 for the pair, plus $20.00 shipping. PM me if interested.
Here is a bb lower to show even groove diameyer. Up to 68.
Red
