Pulley Setup
64Belvedere
11:08 PM
PEI Canada
I am putting power steering on my 64 Belvedere with a 400. I changed the crank pulley to a 2 row pulley and now it's hitting the water pump pulley when running. Bouchillon lists a V6 Magnum 87-91 crank pulley as one that I can use with the stock power steering setup. The inside pulley is slightly smaller. Anyone use this setup or what have you used?
tell us the measurements of your water pump pulley. You may have one for an A/C car. I had this same problem and had to get a new crank pulley and water pump pulley for everything to work.
Water Pump Pulley is 7 inches OD and the crank Pulley is 6.5 inch Double Row.
