Aron Gleason
Wtb a single groove crankshaft pulley for a 440.. 6.5 inches in diameter and 2.5 inches in depth.
6 bolt holes.do you have a part number also how many holes
6 holes.do you have a part number also how many holes
Then don't post a part number that is WRONG because that is what that pulley is that you posted!!Wrong. I'm looking for a crankshaft pulley for a '68 440 with the offset hole.
I was asked to post a part number.Then don't post a part number that is WRONG because that is what that pulley is you posted!!
AND you posted the wrong one.I was asked to post a part number.
Umm ok.AND you posted the wrong one.
This information could help in the future. Obviously the seller did not know or care if he sent you a bent pulley anyway.The ebay seller listed it as a 440 pulley
My pm's are full.. how do I delete them?Aron pm me with a number to reach you at
That makes no sense, my 2 groove crankshaft pulley that's on the motor measures 6.5 inches wide.This information could help in the future. Obviously the seller did not know or care if he sent you a bent pulley anyway.
Crank Pulleys from www.440 Source.com
Pulley ID thread
Most people use the Search function and arrive here - - - - > How to delete conversations from your inbox...My pm's are full.. how do I delete them?
What exactly doesn't make sense?That makes no sense, my 2 groove crankshaft pulley that's on the motor measures 6.5 inches wide.
Got it. Thank youMost people use the Search function and arrive here - - - - > How to delete conversations from your inbox...
