Purple Shaft Cam ID Numbers
r70rr
8:59 AM
missouri
Hi
Just removed the Cam shaft from my 440.
I, was told it is a 509 purple shaft. 1st part of cam shaft is purple in color.
The numbers on the end are
111031
371704
3/05/2
Can anyone help identify what this cam is?
The list I have is for the older cams and nothing on it even comes close to the numbers you posted....small or big block. Also, all the P numbers are 7 digits.....
Does MOPAR stamp or engrave the part number on the cam shaft ends? Or are the numbers that I, have on the end of this cam, production, serial and date code numbers?
How could I, find info on this?
WANT TO SELL THIS SETUP, BUT DO NOT WANT TO MISS INFORM ANYONE. Have cam, lifters and timing set with about 3000 miles on them.
You could always get a degree wheel and dial indicator. Then check the cam lift/duration @ .050 and compare it to the cam specs.
