Purple shaft cam marked 901396 on one end - any info?
skingjack
12:05 PM
YEG
Pulled it out of my 383 RR; now replaced with a Voodoo cam but for curiosity sake, would like to know what the specs for this cam might be ( old 484 or 509 cam?). Google search yields no results; can anyone shed some light on this camshaft. Thanks,
Jack
One place short of a factory part #. Might be the vendors # if they weren't sourced in-house. Measuring the lobes lift x 1.5 might be easier if you have a caliper.
If the camshaft itself is purple, then maybe compare your "partial number" with the available Direct Connection big blog purple shaft cams? If it's hydraulic, I think your only options were a 271/471 (?) hemi-grind; 284/484 & 292/509
Check my post on Mystery Cam lots of good info on I.D. the purple shafts from the forum.
