Pushbutton Automatic cable going into trans on 62 Plymouth leaks
George Funk
9:35 PM
Lincoln, Ca
Is there a kit to fix trans cable going into auto trans housing? Silicone does not work
I believe some members here have had good luck with heat shrink tubing.
Mike
Use this...
https://www.mcmaster.com/7270K2/
Pull the able loose at the trans end, clean it throughly & shrink the tubing over the cable including the steel area this exposed beyond the adjuster....
Readjust the shift cable when you reassembled it..
