QA1 Lowers with sway bar
tjdriscoll
7:43 PM
USA
Hello all,
I've been in the process of rebuilding my entire front suspension on my '68 Charger.
Today while pressing in new pivot shaft bushings, I bent one of my lower control arms. I am beyond mad at myself at the moment now that I have to find a replacement. Trouble is, it doesn't seem like there are many LCAs available out there. Ones I did find do not have the sway bar tab.
I did stumble across QA1's tubular LCA and am considering it. I did purchase their uppers and their adjustable shocks for this build. The problem it looks like is that they don't run a sway bar unless you go with their tubular k-member setup which is not something I want to pursuit. I already purchased a Hotchkis front sway bar that would work with my factory LCAs. (not installed yet)
If I go the route and get the QA1 LCAs, can I still use my Hotchkis sway bar? I have a big block car that came with a sway bar from the factory so I'd like to keep one installed.
From what I've seen posted, either here or Moparts, the arms only work with 70- bars. May be wrong though so you would be wise to investigate. Or latch onto some take off stockers.
