b-body-bob
I was wondering if I could get some opinions on this quarter skin I'm installing. With the quarter trimmed to fit, it lays flat up against the car front back and top like it should, but the bottom where it wraps the rocker is no where close to being flat against the bottom of the rocker and against the pinch weld. I included two photos, one showing how it looks with the quarter hanging on clecos, followed by one showing how far it's off when I clamp the bottom where it should be, without the clecos to position it.
I've got some questions about that fit - if I cleco the panel in place, then force the bottom against the rocker, it puts a twist in the panel. If it's set up that way and I take a cleco out, it forcibly pops out so there's a load of stress in the thing clamped up that way. It seems like that would be a recipe for warpage to me, but what do I know? (not much)
I wondered if a) is it normal and I should just get on with it, or b) should I try to bend the bottom so it aligns with the rocker to minimize the stress in the panel?
If it needs bent, what's the hot tip for doing that without wrecking the panel accidentally?
Thanks in advance for advice and comments.
Here's another photo from inside the trunk, to show how good everything fits when the panel is laying on the car with just the clecos in it
