Quarter window in sedan replacement (update)
superbeedave
11:42 AM
Cincinnati, Ohio
Hey guy's, I need some help in replacing the quarter windows in my 69 Superbee sedan. Do I pull the back seat out then the
side panels and then pull front window track weatherstripping. Remove the screw that is on back corner of assembly. How do I get
behind the center trim between the front and side windows to take off the three screws that holds the front window assembly on, would
they have been behind the rubber stripping? Am I on the right track as far as removing the whole assembly goes? Got down to pulling out assembly but it seems to be stuck on the post. I removed the three screws but seems to be stuck. Do they put any kind of sealant on the piece on the post? Thanks, Dave
