on a 67 gtx manual 4 wheel drum, is there any valving inside the distribution block , tried using a pressure bleeder today after replacing wheel cylinders set at about 7psi and barely dripped out brake fluid from the bleeders. Fronts bled fine. Or do I have a restricted rear hydraulic hose?
