Question about Holley CFM
Cornpatch MO
2:05 PM
Southwest Iowa
I could get a REAL deal on a 4250 style Holley. Dual acc. pumps, mechanical secondarys, hand choke, changeable jets in the secondary. My friend said it was a 750 CFM--just what I want for my mild 440. I checked the numbers and found that the 650 and the 750 bottom plate - butterflys is the same on both. And that the carb is only a 650CFM. I am really dis-appointed. He said it really worked well on a 450+ Cu.in. Olds or Buick? that had been warmed up a little. He claimed that I didn't need a 750CFM. even tho the calculators say I do.
What you all think, The engine will probably not go over 5-5500RPM. but I want to get it there in a hurry!! It is about 9:5 comp. and.475 lift cam. I think about small port heads as having more velocity and am open to the idea that possibly I don't need the 750 CFM.............................MO
If it's a deal and the carb is good use it. CFM is mostly a function of venturi area and throttle bore diameter, so depending on the booster style, it probably really is hovering in the 650 range. For the street smaller is better (to a point).
a 650 will pull power on a street 440 to 5100 rpms by the math.it should work fine.as meep said you want a smaller carb on a street motor to increase velocity signal through the venturies.keeps a better throttle responce.
Thanks for the input. I bought that 650CFM list 4777-4 - double pump-mechanical secondarys- rear block has replacable jets carb today. It is fairly clean, but I will put a new kit in it.
Any advice as to how to set it up for my mild 440- 9.5 comp.- dual plane hi- riser- 4 speed -355 rear gear? I am guessing 72 jets front and 78 jets rear to start with...........................MO
Since this is a 4777 I'd change the metering block to allow a leaner main jet for cruise. Those double pumpers are really race carbs and I think with a metering block change it would run a bit crisper. But to answer your question, 72 jets seem a bit big for a 650. I think those had 67 or 68's stock.
I think this is a formula to calculate approximate required CFM:
CFM=RPM/2 times (cubic inches + Cubic inches / (Compression ratio - 1)) / 1728
The 4777-4 Holley double pumper (4150 series) came stock with 67 primary jets and 73 secondary jets. It doesn't have metering plates like the vacuum secondary carbs. The stock power valve is a 6.5". Try the stock jetting and play with it if you want to maximize the performance. As Meep said, these are not the best carburetors for fuel economy.
the much easyer formula is:
cfm=cubic inch x max rpm/3456.that gives a minimum cfm requirement for a stock like street motor.as performance increases so does the cfm requirement.thats why there is no sure carb for a given motor.
So using the above formula and plugging the numbers we get the following.
440 x 5,500 = 2,420,000
2,420,000/3456 = 700.23148 cfm.
So the 650 carb will be perfect for the street.
Thanks all, I do appreciate all the input. Since I bought this carb un-molested for$100 I am going to start out with it. Lots of stuff to tinker with so it will be fun. I have several jets and power valves and pump cams, so I won't have much any more money in it than the cost of an O/H kit. .......................................MO
