Centerline
My '64 Polara has the tapered axle rear end and I see no good reason to change it. However, I do want to make the rear brakes a bit more maintenance friendly by converting to slip on drums.
I have removed the rear hub/drums (I have the correct tool) and now I would like to remove the drums from the hubs without screwing up the hubs or lug bolts. I'm quite sure the drums are swedged and I plan on replacing them so there is no reason to protect them during removal. Is there a recommended way to remove the drum without damaging the hub or lug bolts?
Also, Raybestos drums for the '64 (10"x2 1/2") are available but is there any reason I can't replace them with the later '65-'70 (10"x2 1/2") slip on drums, as long as I don't intend to swedge them on the hubs? Logic says they should be the same except for the swedging provisions on the '64 versions.
Thanks.
Thanks.
