Still changing bulbs and doing general dash troubleshooting... just have to check with you guys - is the oil pressure idiot light supposed to light up when key is turned to ignition?
and the ground for the idiot light is the oil pressure switch at the block....if switch is bad, light will not work. You can test by grounding that wire and then turn on ignition and see if it lights up
