radiator for 440 swap in 64 polara
bdang
5:24 PM
oregon
Have a 64 Polara and took 383 out and installed a motor home (1976) 440 engine. Need new radiator with passanger side top hose and drivers lower hose - just opposite from the 383 engine. I believe I need a 22" one? Can't spend $500 on this either! Minimal clearance room also. Have shroud from a 64 polara parts car that had 318 engine. Will this fit the radiator for the 440 engine? Any recomendations on radiator to buy - specific brand and part number would help please. Saw a Champion brand aluminum that MAY work. Anyone been here done this? Need hoses too that will work for this application as well! I've been told radiator for 1968 Charger would fit?? Thanks, Ruth.
Radiator
I think it would be easier to swap in a water pump housing that has the radiator hose connection on the driver's side. There are LOTS of those around.
Ditto. New (used) pump housing, new hoses, you are done!
