Radiator shroud question
sixt4driver
1:43 AM
Tucson
Does anyone know if a later model factory 22" plastic radiator shroud, like the one Mancini sells, will bolt up to a 22" radiator for a '64 Plymouth? Not looking for period correct - just a shroud that will work even with some modification. Thanks.
Since they are both 22" it most likely will fit against the radiator. The difference is the location and style of the mounting tabs, so you'd likely need to fab up some brackets or adaptor pieces.
That makes sense to me because I don't think the engine location relative to the engine bay is unchanged much for an mid 60s B body to a late 60s B body.
