CompSyn
Mopar electronic voltage regulator with rare one-year only firewall mounting bracket for all 1970 Plymouth Belvedere - Satellite - RoadRunner - GTX and 1970 Dodge Coronet - Charger - SuperBee.
Voltage Regulator Bracket - P/N 2926621 - replaces the missing one from your 1970 B-Body or if you are converting your pre-1970 Mopar B-Body from a mechanical voltage regulator to an electronic voltage regulator, this bracket is a rare one-year only part that bolts to your firewall in the exact place of your mechanical voltage regulator, see picture. This is a bolt-on item. No need to drill extra holes in your pristine firewall. Ma-Mopar already figured it out for us. This is an original correct factory bracket with fastening bolts. It is not a reproduction. Get Real! Get Mopar!
Voltage Regulator - P/N P4529794 - New in box, never installed Mopar script electronic voltage regulator.
Check your application before and ask questions before buying.
Also, be sure to check out my other great Mopar ads!
$75
$75
