HotRod777
Hoping someone might be able to offer some ideas. My problem appears to be opposite of what usually happens. The car is a 66 with a brake system that I did not install. The problem I am having is the rear bias is too light. On a jack in drive I can barely stop the rear wheels from just the drag of the convertor.
The details I know are:
-Wilwood front disc kit (unknown model)
-Newer manual duel master cylinder, correct style for disc/drum (big/little reservoir. bore size unknown).
-Standard manual brake plumbing where the front uses a simple Tee and the rear heads straight to the back.
-New 11" drums with new 15/16" cylinders, new shoes & hardware kit.
(the rear stuff was all replaced by me chasing the issue)
The rears bleed correctly with great flow and I am familiar with adjusting drum brakes, I've even ran them tight to see if it helps.
Nothing I do seems to get "more" to the rear.
Would 7/8" cylinders that Diff Doc sells help? My thinking is that with a smaller cylinder the pistons will move farther giving the same fluid input... am I right???
I really would like to avoid installing a proportioning valve on the front wheels... especially in a daily driver type car.
