I had my 489 rear rebuilt a few weeks ago and got in on the road this weekend and unfortunately it has a howl in it. Richland 3.55 gears and an Auburn posi were installed with bearings, etc. I also cleaned up the axle housing and installed a new axle seals. I re-packed the original tapered bearings and left them in. This car doesn't have many miles on it. I set axle lash at .010 inch. The posi additive from Auburn was added.
I haven't been able to duplicate the howl with it running on jack stands. On the road from about 1500 to slightly above 2000 (35 - 50 mph I guess as I haven't recalibrated the speedo) running on fairly level road with a feathered throttle to hold speed it starts a howl. Let off the gas and it stops. Give it gas to accelerate and it stops.
Increase my Speed higher and it seems to quit or at least lessen to where it's masked by road noise. I don't think it's making noise at lower speed but this old Torqueflight transmission does a lot of whinning as it downshifts at low speed.
No noise around corners after driving the axle ends are cool to the touch so I'm discounting the bearings.
Apparently it's the set up of the gears but in googling it seems that howling while accelerating or while decelerating is more the norm - one the gear pattern is too deep and the other it's too shallow. I haven't really found any instances of howling with a light, feathered throttle to just hold speed. The guy who rebuilt it is a long time mechanic who builds cars and does some racing. He's built a lot of Mopar rear ends for the Mopar community around here.
The pinion nut was tight when I put a wrench on it yesterday.
Anything I could check before calling him? I've probably put about 10 miles on the car checking it out.
