500stroker
- 1:47 AM
- Aug 19, 2012
- Lake of the Ozarks, MO
I have a 66 Satellite that I am trying to chase down a rear of the car vibration The car has a 8 3/4 posi and has been mini tubed and connected with Cal-Trac bars. 500 cid with a 727 auto
The vibration comes on at about 2000 rpm under acceleration, no vibration of the pedal or coasting in neutral.
I have run down the the following to date;
Balanced and checked for straightness rear tires and rims
Replace the entire drive shaft, trans yoke and u-joints
Replaced both rear springs with all new poly bushings
No change
Before I tear in the rearend does anyone have any suggestions.
Thanks in advance
No change
Thanks in advance
