velrob
Im in process of welding everything back together on my 71 charger bee
the dilemma im having is the rear perch mount (picture attached)
The diagram says 57 3/16 (picture attached) but theres no way i can reach that measurement. Im close to 56 1/2. if i move the perch farther back id need to move all panels back then nothing would line up at all.
What i did was place the leaf spring underneath as if i were ready to mount it to see if the holes lined up properly. the mounting hole of the leaf spring sits right below the hole on the perch. Is that how it should sit? I didnt take pictures of that part before disassembling it.
what problems could arise? would that throw my wheelbase off? all my panels fit properly. the entire rear of the car is new panels cept for half of the rails at rear.
trunk closes properly. all lines are good. floors sit properly.
before i weld in the perch mount permanently i thought id better find out
thanks alot.
thanks alot.
