Rear quarter window roller 1970 Coronet
coronet70
9:42 PM
Valparaiso, IN
Rear quarter window roller & tail panel 1970 Coronet R/T
Looking for the rollers that go between the [SUB][/SUB]vertical rear track and horizontal window bracket. Cringing at prices for the whole kit! Just missing the one piece. HELP! Also looking for a nice tail panel for a '70 Coronet R/T.
I'm having a tough time figuring out which one your talking about but just installed that roller kit in mine and kept the old ones. If I have the one you need I'll mail it to ya, can you post a pic? I think your talking about the one that has a roller on each end of a shaft and is mounted all the way to the rear of the window.
yes!
Here is a photo 747
"Yeap" that's the one, I checked and only one is still good but you can have it. PM me your address
I'm needing these also for my 66..anyone got a source for new ones?
Individual pieces....or kits....
SR-280081 1967-76 A-Body (2 needed per car)
1966-70 B-Body (2 needed per car) Black rollers – no pin $ 7.50 ea
SR-280082 1967-76 A-Body( 2 needed per car)
1966-70 B-Body (2 needed per car) White rollers – with pin$ 22ea
346-38124 1967-74 A-Body (4 needed per car)
1966-70 B-Body (4 needed per car) Quarter window Regulator Sleeve $ 8.00 ea
SR-280079 1967-74 A-Body (2 needed per car)
1966-70 B-Body (4 needed per car) White roller Small hole $ 7.50 ea
SR-280080 1966-70 B-Body (2 needed per car) White roller Large hole $ 8.00 ea
SR-270006 1967-74 A-Body (4 needed per car)
1966-70 B-Body (4 needed per car) Regulator Clip $2.00ea
SR-280084 1967-76 A-Body Quarter Window Roller kit (14 pieces enough for both quarter windows) $ 98 kit
SR-280083 1966-76 B-Body Quarter window roller kit (14 pieces enough for both quarter windows) $ 98 kit
302-39275 1970-74 E-Body quarter window hardware set (one window) $ 39.95 ea
Rick what is the part # for the roller in the pic above? Im in need of one also. Thanks!
I found complete rear window kit for my 66 ....a lot less $$ than above...thanks
A local glass shop did all new rollers,windows adjusted, tracks cleaned/lubed on my 72 RR for $100. I'm happy. Maybe you can try a glass shop in your area ?
