sideline
66' coronet 440 with fresh brake kit install from pedal out....(pretty happy with p-jack kit)... 12" disc's, disc/drum-master, portioning valve,bendx power-booster and lines installed...
(Rear brakes kept as oe. drum). I'm changing out the rear slaves to new while i have it apart.
,.keep the same oe size or bore size change is my question? side note- new 3/16 line run front/rear.
i realize there are sizing options and would like to here any results kindly.
thanks in advance!
thanks in advance!
