Rear Wheel Trim Mouldings
plumcharger
2:48 AM
Iowa
Rear Wheel Well Trim Mouldings
Does anyone know where I might be able to obtain rear wheel trim moldings. When I bought my 66 Charger, it had the front two but it was missing the rear ones. I am getting to the point in my restoration where I will be needing them. Does someone reproduce them? If so, I have had no luck fining any.
Hi,
They are not repopped and are very hard to find in OK shape. Best bet is to give Jim Rodebaugh a call in OK. If anyone has useable pieces, he does...918-333-5573.
Mark
I'm pretty darn sure I have a set sitting in my shop here in CT. I will have to take a quick look to verify. I'm not certain of the actual condition either, there may be a ding here or there if that's OK? I'll have to check on that as well.
Mike
I found a set. They should be on the way. If I do not get them, I will keep you in mind. Thanks for the reply.
