The side and bottom measurements are dead on with the photos I posted. I would rethink your measurements. Your top looks about right.I recently put my car back together and my rear window moldings fit perfect.
No your top should be fine. I would do the bottom and sides per my pictures. These were found to be very correct.Ok, so you think I need to adjust the top measurement locations ? (BTW, the yellow tape in the middle is just the center-line of the roof)
Ok, I adjusted to add tape marks on trim side to use your measurements in your drawingNo your top should be fine. I would do the bottom and sides per my pictures. These were found to be very correct.
I went exactly off that drawing and everything went into place just fine. I do not remember having any clip interference. The drawings I posted were from another site and the guy who drew them up did it as a reference for his build as well as to help others. Side and bottom right to a 1/16 of an inch. Those clips need to go in certain places for certain reasons. You can put them where you want but you asked for advice.Ok, I adjusted to add tape marks on trim side to use your measurements in your drawing
The bottom appears very close, so no issue....
Although for the side, it seems that the lower clip is right at the location where the corner meets the top trim ? is that correct from what you recall ?
View attachment 1131728 View attachment 1131729
Ok, thanks... I really appreciate the help & will use the dimensions on the original drawing. As you said it worked fine, so that's great ! Will drill the holes tomorrow....I went exactly off that drawing and everything went into place just fine. I do not remember having any clip interference. The drawings I posted were from another site and the guy who drew them up did it as a reference for his build as well as to help others. Side and bottom right to a 1/16 of an inch. Those clips need to go in certain places for certain reasons. You can put them where you want but you asked for advice.
