howdy, greetings and salutations. im in the process of rebuilding my front end. All new bushings, tie rods, ball joints...and the lot. every nut,bolt,cotter pin was almost like they all fell off. no,,,not junky fall off,,,,,not one bolt or nut or torsion bar gave me a lick of trouble. i was amazed. HOWEVER......the upper ball joints gave me a fight. i had to heat em up real good for them to break, but i got it and all is well in road runner land. painted the control arms after bead blasting....came out nice... gloss black !
i do want to mentoin one thing.....WHAT IDIOT-STICK CAME UP WITH THE SCREW IN UPPER BALL JOINTS????? the threads on those things are so fine its sick. i didnt cross-thread them but man,,,i had to pay close attention so i wouldnt !....and whats up with that ball joint socket????????????? DUMBEST THING I EVER SEEN !....no depth on the socket so it'll fit nicely on the ball joint. i think mopar could have come up with something better than that...and THANK YOUUUUUU, to the dude that suggested that i take the upper control arm off to do this!!! thank you thank you. that would have been a NIGHTMARE!!! TOOK THE LOWERS TO A SHOP TO HAVE THE NEW BUSHINGS R&R'ed. no way was i attempting THAT!.
i marked the cam bolts to make sure they went back in the same way they came out. its still gonna need aligned when im done but im sure that;ll get me close enuff to get the car to the alignment shop.
all in all it went easier than i thought it would and thank you all for offering help when i posted that i was going to do this . well,,,i did it and it all goes back together tomorrow bright and early . thanx so much guys!
