JRINVT
Well I went to do the front drum brakes (Bearing grease had turned liquid and leaked) and found one of the wheel cylinders leaking. Upon opening it there is quite a bit of rust in the bore so I would rather replace it (both actually) then try to hone it. Problem is I cannot find one of the tools that I own that can get onto the bolts holding it to the anchor plate. No socket, 6 point wrench, or ratchet wrench will fit with the suspension parts in the way.
Any Ideas? This is a 10" front brake drum on a 66.
Thanks in advance.
Thanks in advance.
