Charger1969B
Hey Guys,
I have a 1969 Dodge Charger 440 R/T that has had the A/C removed from it, but still has the blower motor intact coming through the firewall. The new wiring harness that was installed is a non-A/C harness. My question is, the blower motor has a ground wire, and another wire coming out of it. If I want to keep the blower motor functional, where do I wire the "hot" wire to? If I simply wire it to a power source won't it continuously run, or is it still operated by the fan lever in on the dash? I can't seem to make heads or tails from the FSM wiring diagram. Any help would be greatly appreciated.
