Repair frame
coronet65
1:38 AM
wisconsin
I have a 1965 coronet with 3 inch spring relocation kit.I would like to put it back to stock.Does somebody make a kit to repair the frame.Or do I have to replace both frame rails.Have not heard about anybody doing this.Seems like there should be something out. Need help thanks
I haven't run across any kits but I would think that patching the frame in the front and then putting everything else back to stock would be fairly easy. Probably the most difficult part would be redoing the spring mounts on the rearend. Good luck
