DWoody
No back up lights after replacing the bulbs. How can I test the reverse light switch on a manual transmission? If I remove it will gear oil come pour out?
Thanks, looks like I need a switch.You can test it in place with an Ohm meter.
Shift trans in to reverse and test the switch for continuity.
If you need to replace it oil will drain out.
