Rim ID
jburt
8:08 PM
joliet il
Any idea what this 15" rim is off of? 2 of them came in a package deal of parts. Thanks.
Your picture has no detail to it. Look at the area next to the valve stem hole for a combination of letters and numbers. Also, look in between each of the lug holes for a letter. Another place to look for clues is the inside of the wheel, between the wheel rims. Once you find that info and post it, it's going to be a lot easier to answer your question. Right now, I can say "yes, these are 15" wheels for Chrysler" and that is all.
Ill get some numbers off them. I just wondered because they are welded solid all the way around.
The "60" is the width - six inches. IIRC correctly, the "K19" is the date code - "K" is the 11th month, and "19" is the date, so November 19th. The 2 and 4 are codes I am unsure of. I'm sure someone will leap in here and let us know!
