Roadrunner seats
Beep-69
7:21 AM
Minnesota
Can anyone help me, what seats will be for a 69 roadrunner bench front. I need both front and back does another year fit thanks in advance
I believe 66 through 70 Rears are all the same not sure on the fronts but I assume the benches are the same for those years. The bigger difference will be the padding and or coverings on the seats year to year. The basic seat frames are pretty much the same for 66 to 70 other than they introduced the high back buckets in 70. Other options would be did they have head rests or none.
This is supposed to be a 1969 bench seat.
iu
I know that 68-70 will fit. Covering is different for each model
Also 2 door cars would have had a split in the seat backs so you could tilt either side forwards. A 4 door car would have a single back on the seat. So look for a seat that has the split rear like above.
