1967_Joe
Rocker Arm Conundrum
I have a bad habit of over thinking things...like trying to decide on rocker arms...
On a 440 (30 bore) with eddy rpm performer heads and a comp cam hydraulic flat tappet cam (.545 valve lift and .364 lobe lift) 241/247 duration at .05" lift, grind XE285HL I'm thinking 1.5 ratio will do but that gets me to .546 lift, maybe 1.6?
Also, the rockers themselves...damn they are EXPENSIVE
Comp cams 1621-16 Pro Magnum Shaft Mount Rollers - $680
Proform extruded aluminum shaft mounted rollers - $230 (Price scares me)
Any other options that you guys have tried in similar builds? Are these overkill? This is a street motor, not track. I am very interested in your thoughts. What would you do? :icon_scratch:
Thanks in advance...
