66_B_Body4ever
Boys I need some advice on rocker arm selection. The heads are a set of ported and flowed 452's, Ferrea 5000 series SS, 2.14/1.81. I'll be using a MP grind .509 lift cam with matched valve springs from MP. 500 ci. bottom end.
This will be a street engine with odd trips to the strip. What rocker arm will give best bang for the buck? Alot to choose from these days...full roller, bushed w/ roller tip, steel stamped...
Bottom line, reliablility and go fast for the $.
Thanks in advance...Jeff
