WTB SBM Power Steering Brackets
Well, for starters, that bracket bolted to the head, bolts to the timing cover.
I have brackets.
As far as a pulley, what year pump?
The one pictured is a saginaw, and there are two styles. Bolt or press on?
Upon reading the A bodies thread, they point out how wrong things are.
I need the two brackets pictured in the top photo.
I need the one that bolts to the head AND the one that bolts to the water pump.
And a pulley.
Thanks.
Google Image Result for https://www.forabodiesonly.com/mopar/attachments/img_3660-jpg.1715063139/
You can have this whole setup for $80 shipped. Brackets/pump/pulley and some hardware.
Got everything but those two brackets...but if I need them I'll let you know
You need these? First picture? Same for all pumps with aluminum water pump.
There is a triangle bracket that bolts to the pump. Second picture.
Third pic is the 2 different styles of pump. Bracket is different.
Looks like the #2 pic has the correct parts.
I need the one with the adjustment and the one that straddled the pressure hose.
This is the pump...late 80's D100 iirc
I’ll have the brackets but wait and see if u find any closer. The brackets will be the same from a 73-78/79 car if that helps u any. Kim
You were needing a pulley.
This is for a press on pump.
Standard 2 groove crank pulley.
5" belt diameter, almost 6" overall.
