scattershield
daredevil
1:41 AM
houston tx.
anyone have pics of their scattershield on a 727 and did you have to use a bfh to make the tunnel work?
Hit on the exhaust on the passenger's side....at least I think that was the deal. I was running manifolds and TTI 2 1/2" pipe. You also have to make sure it has the proper pivot arm bracket in it, and if it has the starter cup that can be moved for either a 130 or 140 tooth flywheel that it is in the right place.
Otherwise, no issues except a gillion bolts to put it all together
Scattershield on a Torqueflite? I thought you were supposed to use a trans blanket on a TF.....
Rev.
Oops.....mine was a 4 speed in which case you use a scattershield. For autos you use either a shield or a blanket. A shield would probably be better for the street, and a blanket for the track.
