Sealed beam conversion
Dreadl0ck
8:19 PM
Sweden
So I went ahead and got some hella knockoffs from eBay to convert my sealed beams because I needed more light output (yes, I do have relays and new wires for everything)
But the quality was so and so. The bulb is impossible to fasten in the correct position and wiggles a bit which creates the worst beam pattern ever seen on a Swedish road. It was supposed to stay in place with just a tiny clip and a rubber boot on the backside.
When testing it in the garage, the bulb exploded leaving gray residue on the inside of the lens, so I need to replace it - and this time I want to make it properly. Problem is that by looking at the pictures of the Hella kits - they seems to be constructed in the same way as my knock-offs.
Can anyone link to a proper set of good quality, working lights, preferable with a good mechanism for mounting the bulb. I'm running quad high beam so I guess it's a H1/H4 combo I'm looking for. Pretty please? Can't afford buying crap again :/
Dan knows his stuff !
