Triple Black 73
I have a Sealed Power CS-661 Cam, a double roller timing set, and 16 lifters for sale. The cam only ran for 20 minutes. I swapped the cam for a CompCam XE256 because the dynamic compression was too lower for the 8:1 pistons we used. This cam is the 383 magnum reproduction cam which used 9.5:1 compression pistons. Runs like a beast with the right pistons.
Here are the specs:
http://fme-cat.com/overlays/part-detail.aspx?brand=SP&PartNumber=CS-661&pt=Camshaft#.UmXVpd_D_IU
Here's the cam running at 900 rpms and 10 degrees of timing.
I'm asking $160 for everything. Will post pics soon. Just ask if you want to see something in detail.
Here are the specs:
