Seat belt bolts
red72
4:20 AM
mississippi
I stripped the driver's side retractable seat belt bolt on my '72 Satellite trying to remove it. I've gotten the bolt out and would like some opinions on a replacement. I would rather put a grade 8 hex head instead of the torx back in there. Has anyone else swapped these out? Thanks.
If I go the hex route it will be the same shouldered bolt only hex. My real concern is that I cannot locate one as I've had no luck so far. The bolt was mis-threaded from the factory and after the torx stripped out I had to bump it with the air chisel to get it out and re-tap the hole. Any idea where I could locate one? The correct bolt would be my first choice.
