Does anyone have any tips on how to remove the temperature sending unit and heater hose outlets on a 440 engine waterpump, mine seem to be seized and i dont wanna break the water pump housing. Thanks
get the area hot with torch or equivalent source then believe or not let a candle melt a little onto the threads. This works because I remove broken bolts all the time at the shop
If you're planning to go all Cro-Magnon on the heater hose outlets with a pipe wrench or some other such implement, do yourself a favor and place a 3/8" (or so) bolt in there first to keep from crushing it.
Instead of heating the pump housing, heat the tubes themselves and quench with cold water. I agree to stuff something in the tube to keep it from collapsing. It may take a couple heat quench cycles. My friend that runs a machine shop showed me this. He does a lot of 30's, 40's vintage motors. You'll be surprised how easy it will come out.
Doug
