Top Banana
hey guys
Quick question regarding vehicle shaking that is felt in the steering wheel along with the entire front end/car shaking noticeably.
I have a 71 Charger 318 power steering power front disk car and it has a really noticeable shake when braking and going in a straight line from around 45-25 miles per hour. Ironically When braking at those same speeds and I have the wheel slightly in a turn or rounding a corner it doesn’t occur. I assumed rotors/ front end and or wheel balance but the wheels were balanced and twice to be certain and the rotors aren’t shaking or pulsating at low and or high speeds. Also tested the ball joints and tie rods and they are all fine. I know it needs an idler arm for sure and I can feel that in the wheel but never had one effect braking, then again I was a GM guy until recently.
Before I go and start changing rotors and wheel bearing, is there anything else it could be. The shake is really noticeable on the steering wheel and it feels as if the car is shaking hard in a back and forth motion almost like an antilock brake.
Any help is much appreciated.
-Top Banana
-Top Banana
