AlienMopar69
Ok I have a 1969 Plymouth Satellite with a 440 and a 727 Tranny. Currently I am trying to switch over from column shift to floor shift with an after market shifter. I have a bench seat in the front.
Here is my problem:
I got a B&M Star Shifter. But when I go to put it in there is only about 1/4" clearance from the shifter handle to the dash board. The seat is moved as far back as it will go and there is no room. But if I go to a shorter shifter I will be leaning over to shift the car.
So What are you guys running in your cars where you have clearance from the dash board. If you could show some pictures and what type of shifter you are using that would be great, or how you installed it with a bench seat.
Thank you for the help
Brian:angryfire:
Here is my problem:
Brian:angryfire:
