Side Marker Bulb #
TL44
10:49 PM
Cleveland,Ohio
What's the bulb for a rear side marker light on a 70 Roadrunner? Can you get them at a local parts store?
Can't tell you what they are on a /70, but they are 194's on my '71.
Do yourself and the car a favor and buy RED LED versions. Draws less amperage so it's easier on the poor old wiring, and they produce WAAAAY less heat which is mo-betta for the plastic lens.
Ok thanks! I know it's a twist & lock base bulb. I'll search for LED's. I bought LED's for my dash lights but I haven't been able to fit my hand in there to remove the speedo cable so I can access them smh lol
Looking up the bulbs online for your car shows a 194. If it's the push/twist, shop for a 53 That will get you to the size that would fit that socket.
Remember, that release on the speedo cable is a squeeze type. I just broke mine thinking i had to lift it.
Ok thanks! I'm going to pull it out tonight so I have it on end when looking.
Alright, my problem is I can't fit my hand up there to get it , idk if dropping the column would help or not.
