There is a nut on the backside of the fenders. Loosen carefully as they strip easy. New ones, quality are available from BEA parts. I got 4 new for my Roadrunner.
There's a bit more to it. First unplug the pig tail, unscrew the large nut holding the assembly to the fender and remove the assembly from the fender. Now for the fun part, the outer bezel and lens will, or should, unscrew from the pigtail/socket side, these two parts often become one over 42 years and being pot metal. I can post pi'c later if needed
