six pack
bigjimmyl
12:38 AM
chicago IL USA
want to add a six pack to my 73 RR the motor is a 76 360 with a mild cam and long tube headers dont know much else except it is pretty strong, backed with a 4 spd and 8.75 w 3.23 gears, any suggestions obviuosly mubers mayching or correct ids out the window so has anyone used the mopar prerfomance setup it actually seems pretty reasonable????
That's your best bet... if you get used stuff, you risk getting junk carbs with worn throttle blades, warped bodies, drilled metering plates, etc. and manifolds that have been cut. Been there, done that. Just put a MP setup on my own car... so boringly easy.
Where are you looking to get the kit from?
